When the machine is filling with water, some of the water is not going into the tub because it is off center. This results in a puddle of water on the floor. A spring was laying under the machine, which we placed back on the machine, but water is still going onto the floor. Could that spring need to be replaced?
In order to provide the most accurate advise I need the complete model number of the washer.
Gene,
Model No. is 110.92281100 and is about 15 years old.
Check the base plate and the tub support for any damages.
