lilsasseysquirt
#1 Posted : Thursday, October 17, 2013 11:15:20 AM(UTC)
lilsasseysquirt
My washer wouldn't stop filling so I put a new pressure valve switch on. Worked great for about a week now it just fills and fills, to the point were it has flooded several times. When I run it I put the knob were the wash cycle would start and it just continues to run water! I checked the hose there were no leaks, I am not sure what else to check. Please help!
fairbank56
#2 Posted : Thursday, October 17, 2013 12:03:04 PM(UTC)
fairbank56
Check the model number, should that be WDSR2080D5WW? Remove front panel, with tub empty, pull pressure hose from air dome on lower left side of tub. Clean any gunk out of end of hose and use a turkey baster or other suitable device to flush hot water through air dome to clean it out as well. Air dome does not come off of tub. Be very careful, you don't want to break the hose nipple off from the air dome. Other possibility is a kink or small hole/crack somewhere in the pressure hose in which case you can just replace the hose.
Eric
