john1955
#1 Posted : 11 years ago
john1955
My Maytag Neptune front load washer will not fill with water. I see an error code "nd" on the display. The instruction service sheet, that is inside the console, says that this means no drain. Everything I look-up asks me to check the pump for blockage. I did this and cannot find any blockage. I checked the continuity of the water valve solenoids and they all test OK. If I manually fill the washer with water the pump empties the tub at the appropriate time. So as best as I can tell the pump is functioning fine. At this point I have no clue how to proceed. Are there any sensors that could be bad that might need to be replaced. Please help.
sidfink43
#2 Posted : 11 years ago
sidfink43
The problem could be in the control board or in the pressure switch , and you may want to start by replacing the pressure switch on spec. If you order from this site and that is not the part that fixes it you can replace it.
You should also download the service manual for the Neptune 3000. You should be able to find a free download on the net, look for the one with the lonesome repairman on the front. Your model is covered in the back, even though that is not noted in the table of contents.
The manual will take you through a whole bunch of diagnostic testing you can do with this model.
washer wont fill with water (Washer Repair)
by amtracker 13 years ago
by ron2011 13 years ago
Maytag washer wont fill with water (Washer Repair)
by volguy 16 years ago
Whirlpool washer wont fill with water. (Washer Repair)
by dfwhip 17 years ago
