My whirlpool ultimate care II washer will fill but will not agitate thru cycle. I am wondering if it has to do with the lid switch and where it is. Thanks for your help in advance.
Need your model number to determine that.
Eric
Originally Posted by: fairbank56 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Need your model number to determine that.
Eric i found 2 separate numbers: LSQ9659PW2 CS1915513
Originally Posted by: smith96 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) i found 2 separate numbers: LSQ9659PW2 CS1915513 MODEL NUMBER: LSQ9659PW2
Originally Posted by: smith96 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) My whirlpool ultimate care II washer will fill but will not agitate thru cycle. I am wondering if it has to do with the lid switch and where it is. Thanks for your help in advance. MODEL LSQ9659PW2
Yes, the lid switch on that model affects all motor operation, agitate, drain and spin. Open control panel, lid switch is on the left. Sometimes the hinge screws come loose and won't operate the switch. You can unplug the switch and jump out the two wires (gray and white) to see if washer will work.
Eric
It turns out that the door hinge was loose. I tightened and closed the lid and it started agitating. Thanks.
Are you referring on the left side in the rear of my whirlpool ultimate ll washer? Thank you
