Shadow99
#1 Posted : Wednesday, May 13, 2009 5:23:10 AM(UTC)
Shadow99
My maytag make a terrible grinding noise during any agitation cycle (even when empty), yet fills & spins fine. Could it be the transmission or something else?
Rick
pete172
#2 Posted : Monday, October 7, 2013 12:38:17 PM(UTC)
pete172
Rick
I am having the same trouble, what model is your washer? Mine is a Bravo X and I noticed when I tilt mine back I had belt debris, and the agtation pulley has a lot of wobble when running ( I carefully tilt it back during a cycle and observed this). As of yet I have not figured a solution out. i will update you if I do.
pete172
#3 Posted : Monday, October 7, 2013 12:56:27 PM(UTC)
pete172
Update the nut that holds the agitation pulley was loose. I left the belt on and the tightened the nut using "jerking motions" as the agitator moves with it. I have only run one load since this but the noise is gone. Hope this helps.
pete172
#4 Posted : Monday, October 7, 2013 1:04:06 PM(UTC)
pete172
Make sure you do not over tighten and use a small amount of serviceable locktite on the threads
Loud grinding noise during agitation (Washer Repair)
by pete172 10/5/2013 6:32:47 PM(UTC)
GE top load washer make grinding noise during agitation and spin, but work fine, just (Washer Repair)
by dchanson55 1/21/2013 4:11:28 PM(UTC)
by kdeldridge 3/22/2008 7:49:40 PM(UTC)
