Would like to suggest, you start your own thread in the Oven Repair section, using Post New Topic. Do not forget to post the complete model number of the oven.
People will then see it is someone with a problem.
This should increase your odds of getting a relevant reply.
Originally Posted by: Gene The thermal fuse for your oven is shown as #30 on the diagram. The oven has to be removed from the cabinet to access the part. - The thermal fuse Part number: AP3885687
Gene. After Self Clean: oven controls function but unit does not heat. Appears the thermal overload fuse has blown. Can this part be tested before ordering and removing?
I too have repeated failures of the thermal fuse after self cleaning. I thought I read, maybe here (but can't find it now), that it's possible the temperature sensor is bad and letting the self clean get too hot. Is this possible even if the regular oven temperature stays pretty much within specs?
Hey Gene I have a free standing electric stove and my wife self cleaned it now the oven will not heat up. I checked power to the elements and there is 120 volts on both sides of both elements but still not coming on. The top burners are working fine. I check the elements and they have continuity and are not grounded. Any ideas?
A 99% probability it is the thermal fuse mentioned above. Located on the back of the oven under the metal cover.
I'm in the same position, however I have continuity throught the thermostat/fuse...any other ideas? Anyone here know where else to test this thing?
I have a whirlpool woc54ecohs04 oven microwave combo I've only used it a few times and cleaned it quit heating had a repair man out he said it was the limit switch he pulled out the unit and tapped on the limit switch and it worked said best thing is not to clean it what the heck the reason I bought this unit was the self cleaning what a rip can you help with a part number Thanks
