Fred Enright
#1 Posted : Tuesday, September 24, 2013 10:02:10 PM(UTC)
Fred Enright
Hi My oven takes up to 40 minutes to ignite. The ignighter is bright orang but no gas seems to be getting through. I have tried manually ignighting with no success. any clues Thanks Fred
HumboldtRepairMan
#2 Posted : Wednesday, September 25, 2013 7:48:19 PM(UTC)
HumboldtRepairMan
Just because the ignitor glows it doesn't mean it's good......The ignitor must be pulling 3 amps or more before the safety valve will release. IF the ignitor is ashy or white in color replace it or test the Ac amp pull and if your under 3 amps it's bad.
Kenmore gas oven not lighting (Oven Repair (including Ranges and Cooktops))
by wingmaster12 11/11/2012 11:11:11 AM(UTC)
PLEASE? Frigidaire Gas Oven Not Lighting? (Oven Repair (including Ranges and Cooktops))
by mikk 4/8/2010 11:02:11 AM(UTC)
