2 Pages<12
krisgoz
#11 Posted : Thursday, September 5, 2013 6:55:52 PM(UTC)
krisgoz
Originally Posted by: garysfl Go to Quoted Post
I appreciate your feedback. I purchased Whirlpool W10189190 which is almost identical. They are both made by Embraco and have the same ratings on the label. The only difference is that the pins at the top of the relay were more narrow than the original. What I did was open the relays for both and looked at the pcb inside. They are both identical, all the way down to the numbers printed on the board and all the soldering points on the pcb. I removed the PCB from the new and placed it in the old one with the old pins so they fit the wires. While I don't like having to use different parts that are not recommended, I had no choice since the part is no longer in production. I am pretty confident that the relay is the exact same relay.
Garysfl - My fridge is having the same problem yours had. Bought the LG recommended part for the Overhead and PTC , but the overhead does not match the original one . I can not access the PTC as it is sealed in the assembly. Wondering how you were able to open it up to switch out the component with that of the [FONT='Verdana','sans-serif']Whirlpool W10189190 . I will be interested to try the same , but my concern is how to open the sealed assembly. Your advise is greatly appreciated.[/FONT]
2 Pages<12
