msebar
#1 Posted : Sunday, August 18, 2013 5:01:27 PM(UTC)
msebar
When using the microwave only not convection there is an electrical burning smell. Everything seems to work fine. I open the Control Panel and I tuned the microwave on and could not smell or see anything fried in that area. When I turn the fan on the burning smell increase. I put everything back together and and left it. When I woke up in the morning the digital display was now very light. I unpluged it and the pluged it in and the display was all jumbled. I removed the unit from the wall. Upon removing the top cover on the upper left side one wire and the connector was fried. From the parts diagram it was the thermostat that the wire was connected to. Here is my question. Do I repair the wire and connector or replace the thermostat also. Will this fix the problem or do you think something else is wrong being there are now display issues. If so can you explain. Thank you very much for your time.
fredpeterson543
#2 Posted : Monday, September 2, 2013 10:17:10 PM(UTC)
fredpeterson543
to stop any further damages to the the microwave , just go to an electric shop and change the thermostat and i think if there are no problems with the connector and wire you can use them.
__________________________
Web Designing Companies in Delhi
JulesLamers
#3 Posted : Tuesday, September 3, 2013 2:20:20 AM(UTC)
JulesLamers
Yeah you should immediately take it to the electrician rather then getting on to fixing it all by yourself.
HumboldtRepairMan
#4 Posted : Tuesday, September 3, 2013 5:43:18 PM(UTC)
HumboldtRepairMan
Listen to these guys..........microwaves are the most dangerous thing you can work on in appliances. Call a service tech or take it to a shop
Frigidaire Dishwasher Electrical Burning Smell While Running...Not From Coil (Dishwasher Repair)
by netwreck94 11/14/2012 5:27:34 PM(UTC)
Kenmore electrical burning smell (Washer Repair)
by swiet3 5/18/2011 10:40:25 AM(UTC)
