Racingguy04
#1 Posted : Thursday, August 29, 2013 11:18:08 PM(UTC)
Racingguy04
Hi, I have a whirlpool duet washer that my wife and I bought used. It worked fine for about 10 loads but now it's giving me an F06 error code, and the motor isn't spinning at all.
The previous owners had a repair man change the MCU out a little over a year ago, but I figured I'd try it anyway, but it's doing the same thing with the new MCU.
the wires I can see with the kick panel removed are all connected and look good.
I tried running the diagnostic test and it gets to C04 and shuts down.
What should I do next? how can I reset the code?
Thanks for the help
HumboldtRepairMan
#2 Posted : Friday, August 30, 2013 3:29:17 PM(UTC)
HumboldtRepairMan
Make sure your blue wires have 5vDC at the motor control.........Then make sure you have 120vAC at the motor control unit..........If you have both it's more then likely a wire harness or motor issue or a main control issue that's giving false readings. Also check the ground wires that go around the unit where there are door switches on the paneling you may have a bad switch bypass them if you have wiring experience. My suggestion is get rid of it before it costs you more money.
Racingguy04
#3 Posted : Saturday, August 31, 2013 1:58:39 PM(UTC)
Racingguy04
Thanks for the reply, I'm afraid that i'm not too experienced with electrical stuff, I did find the tech job aid manual and I found the section about checking continuity but I don't quite understand what you mean or how to test to make sure I have those readings.
I do have multimeter, but do I leave the machine plugged in? turned on?
I did test the blue wires that plug into the motor control unit and got a reading of 5v DC, but the manual I have says that those wires are the serial comm link?
I unplugged both the power supply and the motor connector plugs off the MCU and checked them for ac, but I didn't get any readings. All of this was with the machine plugged in and turned on.
Racingguy04
#4 Posted : Saturday, August 31, 2013 2:09:06 PM(UTC)
Racingguy04
I just did it with the power on, and it running a cycle, it had 120v AC at the pink power supply plugs for the MCU. How can I test to see if the motor itself is getting power? it has the black motor connector cable, and then two green wires that plug in separately, I can't seem to find any info on which wires do what.
HumboldtRepairMan
#5 Posted : Saturday, August 31, 2013 3:15:28 PM(UTC)
HumboldtRepairMan
Here's some helpful video's on your MCU and Duet motor for testing.
testing duet motors - YouTube
