The oven display reads LOC, we self cleaned the oven, then the door would not open, we got the door open but the oven does not work now, only the cook top.. do you think it needs a door lock motor/switch assembley?? Thank you
Your model number is incomplete so i can't give you a parts number you'll have to look it up after you find the correct model number. Yeah that's very possible that's a common problem with ovens they have problems after using self clean it damages the harness or door locks. Check the door lock wires and connections and continuity test the door lock switch. Replace if necessary
