yoyopol2000
#1 Posted : Wednesday, August 28, 2013 4:58:19 AM(UTC)
yoyopol2000
I have an oven that doesnt work.. I ordered a new ignitor and it still doesnt work..Using an AC current probe to measure.. the old ignitor was showing 2.75 after about a minute, wouldnt go any higher. I read somewhere that the range should be 3.2 to 3.6 for it open the valve. When the new ignitor came in I installed it and the oven still doesnt work. The AC current goes to 3.79 after a half a mintute and stays there.
My question is would an value over 3.6 amps cause the valve to not open? Is this a faulty ignitor? Has anyone ever heard of a case like this?
HumboldtRepairMan
#2 Posted : Wednesday, August 28, 2013 3:37:38 PM(UTC)
HumboldtRepairMan
It's usually a minimum of 3 amps to release the safety valve.........sounds like you have an issue with the safety valve not the ignitor.....
Heres a video to help
Oven Safety Valve Testing - YouTube
yoyopol2000
#3 Posted : Thursday, August 29, 2013 4:54:06 AM(UTC)
yoyopol2000
I tried replacing the valve (actually just laying the new valve alongside the existing one and connecting the wires and listening/feeling the new valve) and it doesnt open or close either when the ignitor gets red hot and the current reading is 3.79 Amps.
Could my problem be a defective ignitor? Or should I look at something else?
HumboldtRepairMan
#4 Posted : Thursday, August 29, 2013 3:30:57 PM(UTC)
HumboldtRepairMan
Check main valve (first in line connected to wall supply hose) on the unit and see if you turned or bumped the switch off there's a flipswitch that turns the gas off going to the oven area.
yoyopol2000
#5 Posted : Friday, August 30, 2013 4:38:51 AM(UTC)
yoyopol2000
Where would this main valve be? Near the Top of the stove? The burners on top work fine.. does this valve only control gas to the oven?
HumboldtRepairMan
#6 Posted : Friday, August 30, 2013 12:50:05 PM(UTC)
HumboldtRepairMan
Read my post........................from the supply line from the wall follow it to unit that's the main valve or regulator first thing on unit
Guest (5)
