Frigidaire LTF214OF.S2 front loading washer has worked fine for 3 years. Then several days ago it stopped and would not advance from the wash to the drain cycle. Still had water in the machine but would not restart and could not open door. After some period of time the door unlocked and I was able to open the machine, remove the wet clothes and as much water as I could. Tried to re-start but door would not lock and machine would not refill. Unplugged the washer for a period of time and tried again but still would not lock and start.
Where might I obtain a schematic wiring diagram and what can I do to troubleshoot and diagnose the cause of the problem? I have a multi-meter and experience in troubleshooting appliances. Do most of my own repairs.
Thanks for any help!
Thanks for your prompt response to my query regarding Frigidaire Washer. Is there any way you can send me the schematic and parts list as a pdf? The resolution of the files contained in the referenced linksis very poor and I'm unable to print or read this on the screen. Also, does this washer provide error codes and if so, could you send the technicians troubleshooting guide for evaluating these codes? Thanks again! Originally Posted by: HumboldtRepairMan ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif)
Check inside the top of the unit or down below behind the panel if your unit has one for a tech sheet or check your owners manual. Typically a faulty door lock or a prolonged or damaged drain pump should give you a code but can't guarantee they will. Here's a helpful video don't dismantle the whole unit for the door lock test just the front boot spring off and reach inside. Frigidaire High Efficiency Washer Model: GLTF2940ES0 Repair - YouTube
