rpack41
#1 Posted : Monday, April 27, 2009 1:54:14 PM(UTC)
rpack41
Kenmore dryer stop heating. Everything else works great. I would like to troubleshoot before I start buying parts. Can someone help with the process of elimination? Thank You, Rose rosepack41@yahoo.com:rolleyes:
#2 Posted : Monday, April 27, 2009 3:50:44 PM(UTC)
Here is a wiring diagram
https://www.servicematters.com/d...0Sheet%20-%208528192.pdf
First flip the breaker on/off a couple times slowly. It is not uncommon to loose half the line without tripping the breaker. Better yet measure the voltage at the plug should be 240 volts.
Next would the the Thermal Cutoff (fuse) on the heater assembly.
OR
The heater itself
kayakcrzy
#3 Posted : Tuesday, April 28, 2009 4:46:17 AM(UTC)
kayakcrzy
Make sure you pull the one wire off the element when you check it. If not you will get a false reading. The other thing is the thermal fuse, does not look like a fuse, that you would think. It is located up on the left side of the heater housing, and is round with 2 wires going to it. Pull the wires off before you check it. If you get no reading on either the element or the thermal fuse they are bad. If it is the element, there are two 1/4 inch screws on the housing, one on the left and one on the right. You take those out, and slide down the element, and out. If it is the thermal fuse, that will be easy. Tom ApplianceEducator.com
