Bradfurt13
#1 Posted : Tuesday, August 20, 2013 12:14:02 PM(UTC)
Bradfurt13
I'm having difficulty removing the main hub assembly to get to the point where I can put the new seals in. I have removed the inner hub but this does not appear to use the spanner wrench type removal.
I'm at a standstill as to how to remove this.
See attached pictures.
Thanks, Brad
Bradfurt13 attached the following image(s):
Bradfurt13
#2 Posted : Wednesday, August 21, 2013 8:12:19 AM(UTC)
Bradfurt13
Anyone have any ideas? We are almost out of clothes :)
Bradfurt13
#3 Posted : Thursday, August 22, 2013 5:08:33 AM(UTC)
Bradfurt13
See new picture, Is there a metal lock washer to remove? There is no set screw which is what I was expecting...
This does not have slots for a spanner wrench..I've turned it and that does not seem to loosen it.
fairbank56
#4 Posted : Thursday, August 22, 2013 6:19:39 AM(UTC)
fairbank56
You need the spanner wrench and seal nut tool. Spanner wrench available elsewhere, #35-2968 You may need to block transmission from turning.
Pro TJ22002898 Seal Nut Tool - AppliancePartsPros.com
Bradfurt13
#5 Posted : Thursday, August 22, 2013 9:10:34 AM(UTC)
Bradfurt13
Thank you.
Do I need to remove the white gear for the agitator first or does it come off as a unit?
- Brad
fairbank56
#6 Posted : Thursday, August 22, 2013 10:18:01 AM(UTC)
fairbank56
The white part is the seal nut, it must be removed first. It does not drive the agitator, that is driven by the splines on the agitator shaft.
Eric
Bradfurt13
#7 Posted : Thursday, August 22, 2013 10:53:50 AM(UTC)
Bradfurt13
Is there any good way to get this off without buying a $60 tool?
Are they both reverse threaded?
fairbank56
#8 Posted : Thursday, August 22, 2013 11:06:07 AM(UTC)
fairbank56
Spanner wrench and hammer is the way we normally do it. They are not reverse thread.
Eric
Bradfurt13
#9 Posted : Thursday, August 22, 2013 11:26:11 AM(UTC)
Bradfurt13
Well that explains why I turned it clockwise a little bit yesterday and didn't loosen :o
Bradfurt13
#10 Posted : Friday, August 23, 2013 7:46:24 AM(UTC)
Bradfurt13
Thanks for your help, the main problem was that I thought they were reverse threads.
I got everything off using a standard pipe wrench vs. buying a spanner wrench and seal nut tool for $75.
I appreciate the help.
- Brad
