windrider354
#1 Posted : Sunday, August 18, 2013 8:34:55 AM(UTC)
windrider354
My Jenn-air oven suddenly stopped heating. No error codes. Display shows preheat and 100 degrees. Same problem whether Bake, Convect Bake or Broil.
Neither top or bottom element gets hot, but I can hear periodic clicking like a switch is trying to call for heat.
Appreciate advice, especially if it sounds like a single part I can replace.
Thanks very much.
#2 Posted : Sunday, August 18, 2013 8:53:21 AM(UTC)
I cannot find any tech info on this unit.
Parts for W27400 - AppliancePartsPros.com
But the first thing I would check is the power to the unit.
The heating elements require the full 240 volts.
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
If the power is good and since the unit stays in pre-heat then odds are high that the control board/timer is toast.
I would check the wiring just in case you have a burned off connector or some other wiring problem.
I cannot find a fuse or thermal cut-off in the parts that would stop power to the elements.
windrider354
#3 Posted : Sunday, August 18, 2013 11:06:00 AM(UTC)
windrider354
Power to oven is OK. Now when I first try to heat oven after power up, I get a F5 code. Only the first time.
#4 Posted : Sunday, August 18, 2013 12:30:54 PM(UTC)
Here is what comers up for that error code.
I cannot confirm that it applies to your unit as I cannot find a tech sheet on it.
F5---Hardware and watchdog circuits disagree---Replace clock assembly (also called the ERC)
