mameis
#1 Posted : Sunday, September 25, 2011 8:07:18 AM(UTC)
mameis
I have a Kenmore Elite undercounter dishwasher and while trying to manually open the soap dispenser to see if it had soap, the little latch for the door popped out. Trying to re-insert the post into the hole - the latch will not stay in place and the springy door pulls it back out. Can this be fixed or do I need a new dispenser??
Jim51
#2 Posted : Wednesday, August 14, 2013 8:05:49 AM(UTC)
Jim51
The post that pops out has an actuator arm attached to the end that has fallen off and will probably show up inside the door. You need a #15 Torx screw driver to remove 6 screws holding the front panel on. Recover the actuator arm and press it back on the shaft.
Jim51 attached the following image(s):
Guest
#3 Posted : Saturday, December 11, 2021 5:46:28 PM(UTC)
Guest
Groups:
thanks so much. it really helped us!!!!
