dideyjohn
#1 Posted : Tuesday, August 13, 2013 12:55:02 PM(UTC)
dideyjohn
My oven heats but the 4 burners elements on top don't heat - do not have an electrical diagram, either. The light come on saying they are turned on but the burner don't come on
HumboldtRepairMan
#2 Posted : Tuesday, August 13, 2013 3:34:02 PM(UTC)
HumboldtRepairMan
You're model number is invalid....check in the bottom drawer or on the cabinet in the door area's. Need a valid model number before we can help
dideyjohn
#3 Posted : Tuesday, August 13, 2013 5:37:13 PM(UTC)
dideyjohn
model # is JBP26GOH3AD. There is one more thing I found a black wire that comes from the bottom back of the unit with about 5 other wires and was coming up to the left side of the back of the oven -= not sure where it goes. IT might be the solution - pls hurry so i do not need a repairman
HumboldtRepairMan
#4 Posted : Tuesday, August 13, 2013 5:42:54 PM(UTC)
HumboldtRepairMan
Still an invalid model number find the number on your unit on the bottom drawer area or on the back of the unit...............the black wires could be anything without a picture i couldn't tell you what there from wires generally don't fall off is there burnt wires anywhere or somewhere this may have fallen off? I'm not going to suggest you hook it up anywhere cuz i have no idea where you found them and without a correct model number i can't help much.
dideyjohn
#5 Posted : Tuesday, August 13, 2013 6:26:32 PM(UTC)
dideyjohn
The black wire is a power wire what is wrong wit the number and iu will look further - what number or letter does not make sense
HumboldtRepairMan
#6 Posted : Tuesday, August 13, 2013 6:38:58 PM(UTC)
HumboldtRepairMan
Ge model numbers start out at JGP18........Then skips to JGP30...........Nowhere on the internet or a parts supplier would you find a JGP26....... Also is your unit gas or electric? If it's gas and you have no spark at the ignitors it's something to do with the spark module circuit considering it's all four.........check your spark module.........should be under the cooktop or under a back piece.........
here's a video
https://www.youtube.com/watch?v=ZjjPCJnwUWs
dideyjohn
#7 Posted : Tuesday, August 13, 2013 6:55:14 PM(UTC)
dideyjohn
i know where it gores it hooks to the 1st burner switch with another black wire what is the best way to connect both black wires and connect the n to switch withiuut sodering
dideyjohn
#8 Posted : Tuesday, August 13, 2013 6:59:01 PM(UTC)
dideyjohn
it is electric and i have manual for jbp 26 built around 89 or 90
HumboldtRepairMan
#9 Posted : Tuesday, August 13, 2013 7:01:11 PM(UTC)
HumboldtRepairMan
Very strange all JGP models are gas from what i see.........Sorry can't help i don't work blind with a model number or schematic i can't find
dideyjohn
#10 Posted : Tuesday, August 13, 2013 7:11:30 PM(UTC)
dideyjohn
give me email - i will send wiring diagram
