Originally Posted by: okolehau ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Hi There, I just read a post else-where that suggested the following to reset the dishwasher push the sanirinse button-dry button-sani-rinse button-dry button in that order When I did this I got some spurious readings on the panel. But these disappeared when I pushed the cancel button. I was then able to start a normal dishwasher cycle. Good Luck!
IT WORKED FOR ME THANK YOU
Originally Posted by: BKRMBen ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) IT WORKED FOR ME THANK YOU After 1 week of this same issue "runs for a few seconds and shut off", I finally relented to my wife's "gentle pressure" to fix the dishwasher. This trick worked for me! Once again, I am a hero, for now. :) Thanks Again!
Originally Posted by: April24 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Whirlpool Gold QP111 - tried pushing normal, light, pots and pans - nothing lit up. The only button I could use was the "cancel" - that would run but nothing else. Tried the suggestion on this forum - turned off at the breaker for about 15 mins then hit sani rinse/dry/sanirinse/dry. The machine cycled through a diagnostic and when it stopped I was able to start the cycle - have not had a problem since! worked like magic. only thing i did different is i unpluged washer instead of turning off breaker. washer is working now. keep fingers crossed and hope this fixes problem for good. you guys just saved me a fortune on repairs and service! Thanks a bunch!
Thank you so much for posting this.... worked like a charm!!!
Thankyou!!!!
