Randyvh
#1 Posted : Saturday, August 10, 2013 4:13:40 AM(UTC)
Randyvh
My wife took the dishwasher apart to clean. When I put it back together it gets stuck on the drain cycle and will not drain. Any ideas?
HumboldtRepairMan
#2 Posted : Saturday, August 10, 2013 7:36:15 AM(UTC)
HumboldtRepairMan
She either disconnected the drain pump wires or reassembled it with something in the way of the drain pump..check for 120v at drain pump when pressing cancel drain button.......also check the drain connection and vacuum the drain hose out at the sink to make sure your line is clear............more then likely she reassembled it wrong and something got blocked in it.........go to sears parts website and put your full model number in and you can see a schematic of the breakdown of your sump motor and how to reassemble it....good luck
Randyvh
#3 Posted : Saturday, August 10, 2013 7:44:31 AM(UTC)
Randyvh
She took the insides apart and the door but nothing else. If I turn the dual to final drain it will do that. Kinda weird
HumboldtRepairMan
#4 Posted : Saturday, August 10, 2013 7:48:38 AM(UTC)
HumboldtRepairMan
Sounds like maybe a bad timer/bad timer connection........check take the front panel off and inspect the timer connection and clean it very well and check for loose wiring............jiggle the wires while testing the different modes see if you see any sparks or loose wires..........
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung DMT400RHS Dishwasher Over Level Water Error. (Dishwasher Repair)
by cprodave 4/27/2024 6:24:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
