wauconda
#1 Posted : Tuesday, April 21, 2009 8:13:37 AM(UTC)
wauconda
All of a sudden everything is dead, no digital display, checked electric outlet and it's fine, it looks like no power is going in, is ther an internal fuse that may have to be replaced. Please help.
#2 Posted : Tuesday, April 21, 2009 1:02:33 PM(UTC)
Remove the top grille and open the control panel. Locate the inline fuse (#49 on the diagram) and check it for continuity.
- The part number for the fuse is AP4243230
Here are the breakdown diagrams and Replacement parts for AMANA MVH210W | AppliancePartsPros.com
wauconda
#3 Posted : Wednesday, April 22, 2009 7:38:52 AM(UTC)
wauconda
Thank you Gene, I'll try it.
Wauconda.
wauconda
#4 Posted : Wednesday, April 22, 2009 9:36:18 AM(UTC)
wauconda
Can I get help on how to locate the inline fuse and what precaution should I take to avoid being electrocuted when trying to do that.
Thank you.
Wauconda
#5 Posted : Wednesday, April 22, 2009 2:46:10 PM(UTC)
The first thing you have to do is unplug the microwave. After you'll open the control panel you should see the fuse
UserPostedImage
If you do not fill comfortable with the microwave repair it is better to call a pro.
wauconda
#6 Posted : Sunday, April 26, 2009 1:48:21 PM(UTC)
wauconda
Hi Gene,
So I was able to locate and replace the ceramic in-line fuse. Sure enough, that fuse was blown. Once I put the new one in and closed everything up, the lights came back on, the vent fan worked, and the over the range light worked. Once I tried testing the microwave functionality, the fuse blew immediately again. What do you think could be causing this fuse to pop?
Thanks in advance,
Wauconda
#7 Posted : Sunday, April 26, 2009 2:19:36 PM(UTC)
It can be a broken door switch(es) or a shorted high voltage capacitor (#29 on the diagram). Before testing the capacitor you have to [COLOR="Red"]discharge it[/COLOR].
Whirlpool Microwave died... (Microwave Repair)
by michaellawre 7/4/2014 2:24:47 PM(UTC)
GE Microwave died after boiling water on stove (Microwave Repair)
by jas1234 7/2/2010 12:00:56 PM(UTC)
microwave died (Microwave Repair)
by anrbrackett 5/24/2010 2:04:13 PM(UTC)
MIcrowave died (Microwave Repair)
by TomofWC 5/23/2010 8:35:44 AM(UTC)
by ghagopian 5/21/2009 6:15:42 AM(UTC)
Maytag Microwave died, fuse is good (Microwave Repair)
by TimTN 4/26/2009 2:03:13 PM(UTC)
Microwave died (Microwave Repair)
by klink 2/3/2009 6:44:59 AM(UTC)
