Burntfood
#1 Posted : Friday, July 26, 2013 6:45:03 PM(UTC)
Burntfood
Tappan model # 30-4952-00/02 is heating higher than set point causing burning of food. Is it the temp sensor?
HumboldtRepairMan
#2 Posted : Friday, July 26, 2013 7:07:00 PM(UTC)
HumboldtRepairMan
Heat up the oven to 350 pull the temp sensor connector off in the back and take an ohm reading on the probe you should have around 15-16 ohms if you dont then more then likely it's the temp sensor....
Burntfood
#3 Posted : Saturday, July 27, 2013 7:52:35 AM(UTC)
Burntfood
Thanks.
A troubelshooting guide on another website stated that most temp sensors run 1000 to 1100 ohms at room temp.
The Tappan temp sensor showed 1108 ohms at room temp which would be in line (if the sensor is one the types listed on the troubleshooting site.) I heated it up with a lighter and it seemed to read linear with the heat added and removed. When I turn the oven on it just keeps heating so I cant set a temperature. Thats the problem with the range. The oven stays on constantly. It doesn't regulate. I feel it's the clock/control board.
HumboldtRepairMan
#4 Posted : Saturday, July 27, 2013 12:50:20 PM(UTC)
HumboldtRepairMan
The trick with temp probes is that you have to test them at various tempatures to get an accurate diagnosis don't ever go by just room temp that's why i recommended 350 then test. Good luck yeah if it checks out at 350 i would possibly suspect main board as well but a bad temp sensor can make the oven stay on for a long time. Also take in mind some units will heat up to around 75 degrees over the tempature you set then about 10-15 minutes later it will gradually work it's way down to the temp. Also some units can be between 25-50 degrees off depending on how cheap the unit is and that's just normal unfortunately.
Guest (5)
