2 Pages<12
jjl04002
#11 Posted : Sunday, July 21, 2013 4:32:01 PM(UTC)
jjl04002
I'm gunna give it a shot and try a new shift actuator. I was testing the basket, and I think it is spinning fairly normally.
I did try the RPM test, and the machine is detecting the rotation of the basket. I was kinda hoping it would fail so I could be sure this was the issue, but I suppose it's worth the shot. It is probably this or a control board, and I think this is the cheaper one to try first.
-Jeff
jjl04002
#12 Posted : Wednesday, July 24, 2013 6:51:39 AM(UTC)
jjl04002
Well that didn't fix it :(
I started it up again and got error F7 E6 if i remember correctly...which was a motor fault...
fairbank56
#13 Posted : Wednesday, July 24, 2013 8:08:34 AM(UTC)
fairbank56
Check the motor windings (resistance) as per manual. Check continutiy of wiring between motor and capacitor, motor and control board.
Eric
tyndall00
#14 Posted : Wednesday, July 24, 2013 8:36:11 PM(UTC)
tyndall00
Buying a coat online is a great idea for many people. If you are unable to find anything that is suitable for you in a store, you may find something online that you like. It is also likely that you will find a coat online that is a lot more affordable. Finding a warm coat online can be slightly more challenging, however. Here are some tips that will benefit anyone interested in how to find a warm coat online.
Choose a coat that is long enough for you. Cropped coats are very fashionable right now, but they do not provide you with very much material and do not offer very much warmth. A coat should hit at least at the waist or below if you are looking for maximum warmth. It is up to you to decide how long you want your coat to be.See if the website provides information on how warm the coat is. Certain websites will let you know if the coat is lightweight, medium weight or heavy weight. If you have the option, always try to opt for medium to heavyweight. Depending on the specific store and coat, lightweight may offer less warmth than you would imagine.
Pay attention to what season the website says the coat is designed for. <a href="http://www.parajumpersnorgesaleshop.com/parajumpers-kodiak-women-c-5.html">Parajumpers Kodiak Women</a> Fall and spring coats tend to be lighter weight. Winter coats will generally be the warmest option. Although there are many exceptions to this rule, it is a great way to prevent yourself from buying a coat that may not be warm enough.Turn the vest inside out while still zipped and place it into the dryer. Add two or three tennis balls to the dryer and set the dryer to a low heat. The tennis balls will fluff and move the down as it dries, ensuring the down does not stick together inside the vest.
A72model
#15 Posted : Tuesday, January 28, 2014 7:41:31 PM(UTC)
A72model
How did you finally get the clips opened. I cannot figure out how to pop the clips to open the top of mine. Thanks.
cokeclsc
#16 Posted : Tuesday, April 8, 2014 9:19:07 PM(UTC)
cokeclsc
I am having the same problem... same model after the same length of time. I have changed the actuator and the capacitor, but all I get when it tries to spin or agitate is the hum. My error code is F7 E1. I was able to test the resistance on the motor and they were slightly higher (approx 22 ohms), but on an old meter.
I am not sure if it the motor or the control board. Anything else I can test?
samg
#17 Posted : Sunday, January 11, 2015 8:55:38 AM(UTC)
samg
Did you ever get the Bravos repaired? If so, what was the problem?
samboski
#18 Posted : Sunday, June 11, 2017 10:12:28 AM(UTC)
samboski
I'd bet there's a broken wire - my washer has broken 2 so far:
http://forum.appliancepartspros...han-week.html#post895850
Guest (7)
2 Pages<12
