The 20W bulb for range surface light shorted out. Now replacement bulb stays on continuously, regardless of control panel function. Pretty sure it fused a relay or SCR but don't have a wiring diagram on the unit. Any help here would be appreciated
Originally Posted by: kb4ob  The 20W bulb for range surface light shorted out. Now replacement bulb stays on continuously, regardless of control panel function. Pretty sure it fused a relay or SCR but don't have a wiring diagram on the unit. Any help here would be appreciated I just dropped lower panel to expose sockets and located the 2 main wires cut one and spliced in a 120v switch. Now it turns on/off Rob
