http://www.appliancepartspros.c...ch.aspx?model=FSE747GES1I am doing some guessing here as I cannot find a wiring diagram for this unit.
[COLOR="Blue"]For instance, would it make sense to substitute a thermostat that opens at about 250 degrees? If this makes sense, can you recommend a particular temperature and part number?[/COLOR]
You could run into problems here as the heater may start being controlled by the high temperature thermostat. These thermostats are just safety devices and their contacts will not last very long if the are switched on/off often.
[COLOR="Blue"]Or does the dryer shut down and stay off if the high temperature thermostat opens?[/COLOR]
No it does self reset. Opens at 285 and re-closes at 245 (re the -40 spec)
[COLOR="Blue"]1. The exhaust vent does not appear to be blocked. [/COLOR]
You could try the following to eliminate the venting for sure.
Unplug the unit and disconnect it from the vent system.
Now try a run.
If it now dries OK odds are the vent system needs checking/cleaning.
Be sure to check that the louvers on the outside of the house open correctly.
If you do not want any lint in the house.
Take a pair of pantyhose.
Put one leg into the other and then attach this to the dryer's vent.
Leave enough room so the pantyhose can balloon out like a windsock.
Both the above will let you check the temperature and the air flow.
Note: The above is not recommended for gas dryers due to carbon monoxide concerns.
[COLOR="Blue"]2. The cycling thermostat [/COLOR]
This is a possibility.
[COLOR="Blue"]
3. The heating coil isn't stuck on, since the fuse didn't blow with the fabric temperature dial set at "air fluff."[/COLOR]
Your conclusion may be wrong.
Many units remove power through a set of contacts is the timer when in air fluff so depending how/where the element grounded it may only get power in a heating mode. Without a diagram I am unable to confirm this.
I would check it with a meter though often you can see the grounding point.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal cut-off blows.
Just in case it is not a grounded element.
With all the below the high limit will also have to be replaced.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut). This can be checked by heating up the face of the thermostat. It will not tell you where it actually opens but at least tells you thet it does open. I use my soldering gun but heating it on a stove top element will also work.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
