alk500
#1 Posted : Sunday, July 21, 2013 6:44:32 PM(UTC)
alk500
Front load washer is locked. Won't run, won't unlock. Ideas?
HumboldtRepairMan
#2 Posted : Sunday, July 21, 2013 7:00:40 PM(UTC)
HumboldtRepairMan
Unplug the unit and see if it unlocks........It's more then likely the door lock is faulty which is a common problem on front loaders. If you remove the top you should be able to access the door lock and it should have a release mechanism somewhere on it typically at the bottom you give it a tug check your owners manual. If the door lock isn't the problem then it's the main board that sends the signal to door lock in most cases.
Whirlpool front load washer WFW9620HBK0 problems (Washer Repair)
by ctbirkett 8/28/2023 4:28:27 AM(UTC)
Whirlpool front load washer (Washer Repair)
by Jhennessy 7/1/2017 8:00:18 PM(UTC)
Whirlpool Front load washer shipping bolts (Washer Repair)
by Greg55 6/26/2012 12:38:03 PM(UTC)
