2 Pages<12
dorlando
#11 Posted : 12 years ago
dorlando
I took another look and the tub does start to move a bit before the dogs
meet but the dogs definitely are meeting, then when I release the pulley they separate. At this point I'm not sure if I can do the rest you are talking about. I have to decide if I am going to have someone look at it.
Do you think the transmission is fine but maybe it is just a bearing? There is a local repair shop that charges $45 for diagnosis and then parts plus a little more labor if needed. I don't mind taking it in if it may be something minor, but not for the transmission. Your thoughts? Thanks for your help.
fairbank56
#12 Posted : 12 years ago
fairbank56
I can't really say about the transmission. If it's the lower bearing binding up, that is part of the transmission and is not a normal replacement item. You would have to replace the transmission if that bearing is faulty. As I said, If I was working on it, I would rule out any problem with the motor not being up to the task and go from there. The $45 diagnosis charge is not bad so see what they say and then decide. Let us know what you find out. I will say, that if the washer is in good shape otherwise, not rusting out or anything, it may be worth it to fix. I have a similar GE model that is older than yours. Last year, I had to replace the motor and transmission. Of course, it was parts at a discount only but I refuse to buy the junk washers they are selling nowadays. The only decent new toploader that I would recommend is one of the Speed Queen models and they run around $800.
Eric
dorlando
#13 Posted : 12 years ago
dorlando
is there any chance it can be the lid switch? I just want to rule that out for sure. When I manually press it the tub moves just an inch and you hear the clunk, that is it.
fairbank56
#14 Posted : 12 years ago
fairbank56
Not likely. The motor runs so the switch is closing. If the contacts are in very bad shape though, it could cause a voltage drop at the motor. Another reason for checking voltages at the motor. You could make a suitable jumper to jump it out to rule it out as a problem.
Eric
GE Washer not spinning (Washer Repair)
by zoobteach 10 years ago
by atomicsynth 10 years ago
GE washer not spinning any cycle (Washer Repair)
by j409 11 years ago
GE Washer not Spinning (Washer Repair)
by jkomes 11 years ago
GE washer not spinning out all the water (Washer Repair)
by sbryant73 11 years ago
by Tigerhawk247 11 years ago
by jschust 11 years ago
by jlbyrnes3 12 years ago
by JD0034 12 years ago
GE washer not spinning (Washer Repair)
by mau397 13 years ago
GE Washer not spinning and smells strange (Washer Repair)
by greenfelt22 14 years ago
GE Washer not spinning. Bad motor or transmission? (Washer Repair)
by MrJosh 16 years ago
2 Pages<12
