2 Pages<12
fairbank56
#11 Posted : Tuesday, July 16, 2013 4:27:32 AM(UTC)
fairbank56
It takes nearly 10 turns of the gearcase input shaft to get one turn on the internal spin gear which will give about 3.5 rotations of the clutch hub. You would have to lightly grasp the clutch hub while rotating the input shaft to be able to feel if there is a problem.
Eric
squiggy711
#12 Posted : Tuesday, July 16, 2013 10:22:28 AM(UTC)
squiggy711
Rank:: Member
Yup that is what I did. I held the clutch hub, and rotated it about 45 times just be sure.
fairbank56
#13 Posted : Tuesday, July 16, 2013 11:18:12 AM(UTC)
fairbank56
When the washer goes into drain, does it drain without spinning?
Eric
squiggy711
#14 Posted : Friday, July 19, 2013 8:32:54 AM(UTC)
squiggy711
Rank:: Member
With a extra small and small load setting it spins while draining.
For Medium, Large, and Extra Large settings it drains before spinning.
fairbank56
#15 Posted : Friday, July 19, 2013 9:04:03 AM(UTC)
fairbank56
Well that's interesting. It should always drain first without spinning. After drain the motor should pause for a few seconds and then start again for spin while continuing to drain. If it starts draining and spinning at the same time, the neutral drain mechanism in the gearcase is not working properly. I still think the jerking motion is gearcase related. Run it in spin in delicate cycle. This should be low speed and cause the spin gear to rotate at about 117rpm which is about 2 times per second. Is the jerking now at about that rate versus 3 times per second in high speed?
Eric
squiggy711
#16 Posted : Friday, July 19, 2013 3:18:42 PM(UTC)
squiggy711
Rank:: Member
Yes that is correct about 2 jerks per second on the delicate cycle.
jetpad
#17 Posted : Monday, September 19, 2016 12:25:54 PM(UTC)
jetpad
For anyone else having this problem, I solved it with the counter balance spring. The place where mine connects had rusted through and I (in error) attached it to what I thought was the right hole (but on the tub and not the the frame). That did not fix the problem.
When I connected it to the frame using a hole near the rusted hole, the tub would spin without jerking and it solved the problem.
2 Pages<12
