the heater sheath to my convection oven burnt out so i replaced it, when i tested to see if it works, the oven worked but the microwave stopped giving heat, any suggestions?
if by sheath you mean the cardboard like piece on the right side of interior, then the magnetron is what burned it out. magnetron will need to be replaced
thanks for replying, but i mean the convection element, what happened was, the oven stopped heating but the microwave still worked, so i replaced the convection element since it had crumbled, now that i put everything together, the oven works but the microwave stopped heating, any suggestions?
