spatman
#1 Posted : Friday, June 21, 2013 8:12:54 AM(UTC)
spatman
When I select the "Proof / Keep warm" setting on the control, the top element comes on and the temperature just keeps getting higher and higher.
#2 Posted : Saturday, June 22, 2013 3:26:57 PM(UTC)
Your model number is missing a bunch of alphanumerics at the end (probably 5 or so characters).
I therefore cannot find any tech info on it.
Please check it.
spatman
#3 Posted : Saturday, June 22, 2013 8:19:41 PM(UTC)
spatman
Denman, I located the full model number
KFDRP407HSS11
I have been told by a local appliance repair shop that it is not possible to test the control panel for proper operation other than replacing it and seeing what happens. It was suggested that the two items to be replaced are
4452443 control module
9759149 electronic control
It was also suggested that the oven door seal could be allowing heat to escape and overheating the control module. Your thoughts please.
#4 Posted : Sunday, June 23, 2013 1:43:06 AM(UTC)
Sorry still cannot find any info on KFDRP407HSS11.
Are you sure that it has the "F" in it?
spatman
#5 Posted : Sunday, June 23, 2013 8:35:11 AM(UTC)
spatman
Sorry, no F in the number
KDRP407HSS11
#6 Posted : Monday, June 24, 2013 1:46:22 AM(UTC)
Parts for Whirlpool KDRP407HSS11 Range - AppliancePartsPros.com
See the attachment for the tech sheet
Have you tried unplugging the unit to see if this problem will clear?
Perhaps the unit is just confused.
Since all other functions are OK I would say that the control board is toast.
File Attachment(s):
KDRP407.pdf (359kb) downloaded 5 time(s).
Whirlpool Oven Temperature Low (Oven Repair (including Ranges and Cooktops))
by topthumb 1/23/2023 11:37:05 AM(UTC)
Thermador oven temperature fluctuates (Oven Repair (including Ranges and Cooktops))
by tylert 7/4/2022 1:19:07 PM(UTC)
Oven Temperature Regulation (Oven Repair (including Ranges and Cooktops))
by Tumbleweed_2 1/27/2022 9:20:22 PM(UTC)
Jenn-Air Oven Temperature Problems (Oven Repair (including Ranges and Cooktops))
by AndyBonner 9/3/2016 8:29:21 AM(UTC)
Kenmore oven temperature issue (Oven Repair (including Ranges and Cooktops))
by Pmacd 11/12/2015 5:16:07 AM(UTC)
Oven Temperature Sensor Beyond F3 (Oven Repair (including Ranges and Cooktops))
by salquint 10/31/2015 8:36:13 AM(UTC)
Upper oven temperature lower than displayed by 75degrees (Oven Repair (including Ranges and Cooktops))
by BillIan 10/22/2014 12:41:56 PM(UTC)
Oven temperature low (Oven Repair (including Ranges and Cooktops))
by Yuan 5/20/2014 4:27:30 PM(UTC)
Won't maintain oven temperature (Oven Repair (including Ranges and Cooktops))
by Ingridmoore66 4/19/2014 5:50:15 AM(UTC)
older model GE Profile oven temperature won't stay on (Oven Repair (including Ranges and Cooktops))
by kysowns 1/8/2014 8:45:42 PM(UTC)
Kenmore oven temperature problem (Oven Repair (including Ranges and Cooktops))
by dro53 9/11/2013 8:17:13 PM(UTC)
Oven temperature Control on GE XL44 B (Oven Repair (including Ranges and Cooktops))
by Kpaul 1/14/2013 1:28:20 PM(UTC)
Oven Temperature 25 degrees lower than display (Oven Repair (including Ranges and Cooktops))
by geebekazoo 12/12/2012 10:27:31 AM(UTC)
Oven Temperature decreases while baking (Oven Repair (including Ranges and Cooktops))
by gturzo 11/6/2012 3:33:40 PM(UTC)
Oven Temperature Adjustment Not Working (Oven Repair (including Ranges and Cooktops))
by Texdel 5/4/2012 1:14:38 PM(UTC)
