everettwayne
#1 Posted : 12 years ago
everettwayne
dryer element for dishes will not heat.
#2 Posted : 12 years ago
Parts for Whirlpool DU811SWPQ4 Dishwasher - AppliancePartsPros.com
See the attachment for the tech sheet
Remove power from the unit and check the heater for any physical damage.
If OK, check it with a meter. Should be around 20 to 30 ohms.
Check the thermal fuse for the heater, should be 0 ohms.
File Attachment(s):
DU811.pdf (215kb) downloaded 3 time(s).
dish washer runs with doo open (Dishwasher Repair)
by Guest 3 years ago
Dish washer not cleaning dishes KDTE204EPA1 (Dishwasher Repair)
correct orientation of plugs on ASKO D3122 anti flood microswitch. dish washer ? (Dishwasher Repair)
by turbo1600 5 years ago
Whirlpool dish washer WDF110PABB2 Filling but not washing. (Dishwasher Repair)
by KG4MXV 7 years ago
Kitchenaid dish washer leaking from below (Dishwasher Repair)
by chrysrobyn 8 years ago
Dish washer stopped and want finish, all lights off (Dishwasher Repair)
by b.alford002@comcast.net 10 years ago
How to replace motor bearings on Kitchen Aid KUDSO1FLSS1 dish washer (Dishwasher Repair)
by rajfixplumming 11 years ago
Dish washer stops 14 Min in to cycle (Dishwasher Repair)
by Wayne_44 11 years ago
Dish washer no lights on panel stopped mid cycle (Dishwasher Repair)
by 56Gomer 12 years ago
by poloman 12 years ago
Dish Washer (Dishwasher Repair)
by jobronie 12 years ago
Dish washer won't dispense water. (Dishwasher Repair)
by Tom Loszchuk 12 years ago
GE Dish Washer Stops midcycle (Dishwasher Repair)
by mwpresnell 12 years ago
drain on dish washer small leak (Dishwasher Repair)
by red&green 12 years ago
