I just replaced my drain motor, but my washer is still not draining. Did I do something wrong or could it be a relay or something else. Everything else on the QC seems to be working fine.:confused:
Groups: APP Team
Hi. Did you replace the motor on the left or on the right of the pump housing? Have you checked if there is 120Volts AC is coming to the drain pump motor from the control? Here are the breakdown diagrams and parts for LG WM2487HRM - AppliancePartsPros.comSimon.
Thanks for your reply. I rechecked everything and one of the wires was loose....fixed the problem.:)
Groups: APP Team
I'm glad that you fixed the problem. Thank you for using our forum.
Simon.
