my unit is not cooling the fridge side, the top vent blows a little air but it makes a small amount of ice on the vent, I asked somebody and he said that it may be the baffle or thermostat. if this is the problem can you help me to locate the part and is it something that I can repair. :(
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's open. If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too. If so check the defrost heater, defrost thermostat. Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
