Pros- 2 issues here lucky me!!
I have a microwave that's door has broken under the handle causing the glass to want to slip out. That is now help in place with Gorilla Tape. Works great/Looks awful. IS there a part out there still (BLACK) that I can replace with? 2nd issue MOST of the buttons on control panel do not work, the only button that really works is the 30 second button and the clock AM buttons, so the lower buttons it seems are working but the majority are not. It heats things great!
Also, my lights don't work, not sure if the bulbs or burnt or other, but that info might be helpful.
I want to fix these 2 things any advice.
Thanks Czech!
Rank:: Advanced Member
Groups: APP Team
Hi.
You didn't provide the model number of the unit.
Simon.
Attached Jvm1850bh02 Thx czechaman attached the following image(s):
model number jvm1850bh02 GE Spacemaker 1800xl
Groups: APP Team
Hi. Regarding the broken door most likely you need the outer door frame Part number: WB55X10476
Regarding the touch pad first disconnect the flex ribbon from the control board and clean the edge with the isopropyl alconol. If that doesn't help - replace the touch pad/ control panel assembly Part number: WB07X10785
