AppliancePartsPros.com
Appliance Repair Help
Washer Repair
washer control panel all lights flashing -wont start
The washer would not start despite showing power to the control panel. I replaced the control panel but now all the panel lights flash in synchrony constantly and the washer does not start. we pulled the plug and left it sit for 48 hours but the same thing is happening. Is there a ground somewhere? How to I fix? thanks
Did you transfer the model select connector from the old control board to the new one? It's the connector with a single jumper wire on it.
Eric
Originally Posted by: fairbank56 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Did you transfer the model select connector from the old control board to the new one? It's the connector with a single jumper wire on it.
Eric I do not know what that is. Where on the old control board is it located? A wiring diagram would help. We connected all wires that needed to be unplugged from the old control board to the new. thanks
Next to the large transformer on the old circuit board there should be a connector with one or two jumper wires on it. This must be transfered to the new board. It is the model selector plug that tells the processor which model washer you have. The board can be used with different model washers.
Eric
Moving the plug from the old control panel to the new one fixed it, but mine had a total of 2 wires or four ends plugged into the jumper. Thanks so much for your assistance. The wife is happy again!!!!
Mine didn’t have a jumper on the old board
I need a picture of where next to the large transformer is
Washer Repair
