freqflyer
#1 Posted : 12 years ago
freqflyer
My dryer quit heating. I disassembled it and found the heating element to be broken. I replaced the heating element. I have done this before without problems. I reassembled it and it still wouldn't heat.
Here's what I have checked.
1. The new heating element is installed properly and not touching the case or otherwise grounded to anything. I checked visually and with an ohm meter.
2. I removed a wire from each of the three thermocouples in picture one and checked for continuity. The ohm meter read 0.
3. I check for power at the heating element. See picture two. The black wire and the orange with black stripe both read 120 volts when checked against the case. This is with the dryer on or off. The purple wire reads nothing. When checking the orange and black ones together I get 0 volts.
I checked the purple wire against the case and I get no continuity with the dryer off and a fairly low ohm reading with it on.
The replacement element they sold me is HHWE11X103C.
What could be wrong and what else can I check. The way I see it. I have 110 to the heating element and I have a switch neutral to the heating element. Shouldn't it be getting hot?
Thank you in advance for your prompt reply.
freqflyer attached the following image(s):
freqflyer
#2 Posted : 12 years ago
freqflyer
I checked the temperature selector switch according to the video on here and it appears to ok.
Simon / APP Team
#3 Posted : 12 years ago
Simon / APP Team
Groups: APP Team
Hi.
I'm not sure (can't get the exact wiring diagram), but it looks like the purple wire has no 120VAC. Check the power outlet if there is 230VAC. Reset the breakers.
If you have 230VAC to the dryer check if the motor contacts M1-M2 are closed when dryer is running.
Check the connector block at the back.
Post the results.
Simon.
freqflyer
#4 Posted : 12 years ago
freqflyer
Actually the purple wire it supposed to have 120 to it to make the 240 for the elements. I traced that wire to a limit switch on the front of the dryer by the motor. It was disconnected I must have kicked it when I had the front off the dryer and not noticed. Dryer works now.
Thanks for the replies.
Simon / APP Team
#5 Posted : 12 years ago
Simon / APP Team
Groups: APP Team
I'm glad you solved the problem.
Simon.
