2 Pages12>
strat1953
#1 Posted : Sunday, May 19, 2013 4:10:22 PM(UTC)
strat1953
my ge freezer section was all iced up. i jumped the defrost thermostat and the heater came on after a few hours and started defrosting.so i assumed it was bad and ordered a new one.now i never see the heater come on? i checked the defrost thermistor and it reads 19.68 k ohms. the freezer will not get colder than 17 degrees and still has alot of frost on the top half of the coils.it was at 32 degrees with the old thermostat when it was all iced up.now at 17 degrees but will not get any colder? what do you think the problem is?
#2 Posted : Monday, May 20, 2013 2:25:15 PM(UTC)
Originally Posted by: strat1953 Go to Quoted Post
...still has alot of frost on the top half of the coils...
Hello,
How is the other half of the coils covered with frost?
Does the fan in the freezer work?
strat1953
#3 Posted : Monday, May 20, 2013 2:44:07 PM(UTC)
strat1953
the top 6-8" of the condenser is covered with very thick frost.(the part closest to the light bulb) the bottom half has some frost. the fan does run. do you thing the defrost thermistor being at 19.68 k ohms is the problem? or the main board??
#4 Posted : Monday, May 20, 2013 2:54:26 PM(UTC)
It looks to me like there is something wrong with the sealed system. Can you post a picture of the coils please?
BTW, this is evaporator. The condenser is on the back of the refrigerator.
strat1953
#5 Posted : Tuesday, May 21, 2013 12:47:58 PM(UTC)
strat1953
here 31-2729 - WSM2420D1WW Laundry center.pdf (303kb) downloaded 35 time(s).s a pic. this morn it was 4 degrees in freezer and 36 in fridge.pretty close,but heres what it looks like.
strat1953 attached the following image(s):
strat1953
#6 Posted : Tuesday, May 21, 2013 3:03:02 PM(UTC)
strat1953
heres a pic. freezer was at 4 degrees this am. i installed a new thermister last nite. still will not go to 0 degrees?? fridge is ok. its at 36 degrees. thoughts on a fix ??
#7 Posted : Tuesday, May 21, 2013 3:09:43 PM(UTC)
I do not see any pictures, just a frame. Can you redo it please?
strat1953
#8 Posted : Tuesday, May 21, 2013 3:10:01 PM(UTC)
strat1953
freezer pic
strat1953
#9 Posted : Wednesday, May 22, 2013 11:37:36 AM(UTC)
strat1953
heres the pic. any ideas? Fan works fine, and freezer is at 5 % today but i set it to 0 % last nite?
#10 Posted : Wednesday, May 22, 2013 3:17:17 PM(UTC)
Thank you for the picture.
There is nothing wrong with the sealed system. It's not defrosting properly. Pull the refrigerator out of the wall and unplug it. Remove the wire from the J9 terminal on the main control board and measure the resistance between this wire and the wire connected to the J7-9 pin.
If the reading is about 22 Ohms, replace the main control board.
- The main control board Part number: WR55X10942
Guest (5)
2 Pages12>
