dearie47s
#1 Posted : Friday, May 17, 2013 8:27:36 AM(UTC)
dearie47s
How do I manually unlock my washer door, if error code is flashing F33, and it will not complete any cycles? What is F33?
Joe / APP Team
#2 Posted : Friday, May 17, 2013 11:29:39 AM(UTC)
Joe / APP Team
Dearie, The F33 error indicates there's an issue with the drain pump or wiring between the drain pump and the CCU (central control unit). Does the washer drain ? If the washer doesn't drain, the door stays locked and the washer wont spin, either.
Manually Unlocking the Door Lock System 1. Unplug washer or disconnect power. 2. Remove the lower kick panel. 3. Reach up along the inside of the front and locate the bottom of the door switch/lock unit. 4. Located on the bottom of the door switch/lock unit is a teardrop shaped tab. 5. Gently pull the tab down about a 1/4˝ or until a click is heard. 6. The door may be opened.
