PepperVal
#1 Posted : Thursday, May 16, 2013 8:36:29 AM(UTC)
PepperVal
Washer is in a coin op facility. The machine will run through all cycles appropriately, but will not drain. During the drain cycle; the drum spins, pump and hoses are not clogged, belt is good, no funny smells.
In addition: What is the process behind the drain cycle? The pump is not operated electronically, so does it have something to do with the brake?
fairbank56
#2 Posted : Thursday, May 16, 2013 9:24:34 AM(UTC)
fairbank56
The motor runs in opposite directions depending whether it's in agitate or spin mode. Only in spin mode, does the pump rotate in a direction that pumps the water out. If it rotates freely and there is no clog in the pump or hoses, either the pump impeller is bad or there is clothing between the tubs at the drain exit.
Eric
Ge dishwasher will not drain (Dishwasher Repair)
by Handyman924 2/24/2017 8:05:27 PM(UTC)
maytag washer will not drain water (Washer Repair)
by mathy10544 12/13/2015 8:54:09 PM(UTC)
GE front load washer will not drain (Washer Repair)
by Sandmann01 6/22/2015 1:24:04 AM(UTC)
Washer will not drain (Washer Repair)
by Artnlp 5/3/2015 7:34:59 AM(UTC)
Washer will not drain in Normal cycle (Washer Repair)
by rober luck 4/20/2015 9:10:47 AM(UTC)
by charles140 10/10/2014 8:21:01 AM(UTC)
by hurler72 11/25/2013 10:59:35 AM(UTC)
topload washer will not drain or spin (Washer Repair)
by olac757@gmail.com 8/9/2013 9:08:21 PM(UTC)
Whirlpool dishwasher will not drain (Dishwasher Repair)
by PeterZ 8/6/2013 7:21:51 PM(UTC)
Washer will not drain or spin (Washer Repair)
by Fixit Dad 5/23/2013 4:26:49 PM(UTC)
Whirlpool Washer will not drain unless open and close lid (Washer Repair)
by twhistle 2/28/2013 8:16:58 AM(UTC)
Washer will not drain or spin, new pump and lid switch (Washer Repair)
by tangerine30680 1/26/2013 12:42:38 PM(UTC)
I replaced lid switch, still washer will not drain or spin (Washer Repair)
by dnschrstn 11/12/2012 12:39:16 PM(UTC)
washer will not drain before the spin cycle (Washer Repair)
by tondot 11/11/2012 5:32:56 PM(UTC)
Maytag Washer Will Not Drain or Spin during White or Color Cycle (Washer Repair)
by ametz69 11/6/2012 5:52:41 PM(UTC)
