gleadley
#1 Posted : 12 years ago
gleadley
Just replaced auger motor and the front door display main board, the water works as before but still no ice will dispense. What's my next step?
#2 Posted : 12 years ago
Does the ice dispenser light go dim when you push the lever?
gleadley
#3 Posted : 12 years ago
gleadley
No, light stays the same , the door solenoid works
#4 Posted : 12 years ago
Check the wires coming out of the freezer door at the bottom hinge.
Remove the ice bin. Tape in the door switch. Disconnect the wires from the auger motor and check for 120 VAC between them while the dispenser is calling for ice.
gleadley
#5 Posted : 12 years ago
gleadley
No power ?
#6 Posted : 12 years ago
What did you mean?
gleadley
#7 Posted : 12 years ago
gleadley
i checked the power to the auger as you suggested there is no reading there
gleadley
#8 Posted : 12 years ago
gleadley
i checked to see if the auger is getting 120 v and its not
#9 Posted : 12 years ago
If there is nothing wrong with the wiring under the door then very likely the problem is a bad main control board. If you need the correct part number, verify and repost the model number of the refrigerator please. The model number you posted does not come up.
gleadley
#10 Posted : 12 years ago
gleadley
Ok thx Gene
