This range is MAYBE 2 years old. Less, I think... My wife went to open the oven door today to take out a pie and one side of the oven handle came loose. Ofcourse there's no easy way to just simply screw it back in. Does anybody have some kind of a service manual for this? I'm used to taking things apart... This can't possibly be that difficult, but I'd like to have some kind of a guide so I don't take apart things I don't need to.
Thanks very much for any help you can give!
-Andy
PS - The door didn't fall off. I meant type door HANDLE... Sorry
Hi Andy, Remove the door from the oven as described in the Installation instructions (page 14). Place the door on a flat surface with the door handle facing down. Remove the screws secured the inner door liner and you will see what to do next. Gene.
Hi Gene - I figured it would be fairly simple... just making sure. Being a computer tech, I've taken a LOT of things apart over the years but this would be my first oven. Sometimes you never know just by looking at it! I'll take care of it tonight and let you know if I run into any problems. Thanks for the reply!:) Andy Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Hi Andy, Remove the door from the oven as described in the Installation instructions (page 14). Place the door on a flat surface with the door handle facing down. Remove the screws secured the inner door liner and you will see what to do next. Gene.
