coldoc89
#1 Posted : Thursday, May 9, 2013 7:06:35 PM(UTC)
coldoc89
My wife tried to bake a chicken for dinner while we were out of the house and got home to find that the chicken was not cooked! :( I had the bake and broil elements checked and they're both fine. I replaced the temperature sensor hoping that was the problem but did not fix the problem. All the buttons on the touch pad work and when the oven is set to bake, it warms up but never reaches the set temperature. :confused: Does the control board need to be replaced??
Thanks for your help!
ApplianceJunk
#2 Posted : Friday, May 10, 2013 5:28:59 AM(UTC)
ApplianceJunk
You should check to make sure the oven has 220-240 volts going to it to start with.
Then check any thermal fuses.
coldoc89
#3 Posted : Sunday, May 12, 2013 9:14:25 PM(UTC)
coldoc89
Hi ApplianceJunk,
I checked the outlet and it is putting out(..going to it) 240 volts. How do I check the thermal fuses?
Gas Oven not heating up (Oven Repair (including Ranges and Cooktops))
by Guest 2/8/2024 7:09:48 PM(UTC)
upper oven not heating up to desired temp. it's off by about 50 degrees (Oven Repair (including Ranges and Cooktops))
by Guest 10/14/2022 12:50:23 PM(UTC)
Oven not heating up and gas smell in house (Oven Repair (including Ranges and Cooktops))
by DJKNY71 1/18/2017 7:06:47 AM(UTC)
by gplundell@msn.com 4/21/2015 3:33:43 PM(UTC)
by paulgbernard 2/14/2015 3:50:00 PM(UTC)
Oven NOT heating up at all (Oven Repair (including Ranges and Cooktops))
by bkevans88 10/31/2014 6:14:02 PM(UTC)
Oven not heating up right. (Oven Repair (including Ranges and Cooktops))
by clueless78 10/17/2014 2:49:30 PM(UTC)
Oven not heating up after self cleaning (Oven Repair (including Ranges and Cooktops))
by JD40 3/18/2014 6:25:03 PM(UTC)
oven not heating up (Oven Repair (including Ranges and Cooktops))
by vwforonda 8/21/2012 5:54:27 PM(UTC)
GE Gas Oven not heating up correctly (Oven Repair (including Ranges and Cooktops))
by ichengsd 6/19/2012 4:05:19 PM(UTC)
convection oven not heating up to correct temperature (Oven Repair (including Ranges and Cooktops))
by cecelo 1/17/2012 6:57:16 AM(UTC)
by cren722 12/20/2011 1:14:07 PM(UTC)
oven not heating up to temperature (Oven Repair (including Ranges and Cooktops))
by buhr 9/12/2011 11:43:11 AM(UTC)
by doette-56 3/6/2011 4:37:05 PM(UTC)
by rpeters23 2/22/2011 5:17:07 PM(UTC)
