Elle Dee
#1 Posted : Wednesday, May 8, 2013 8:14:42 AM(UTC)
Elle Dee
I went to use my oven a couple of days ago. I pushed the button to turn it on and immediately heard a "bzzt" noise (electronic shorting sound) come from the vicinity of the clock/control panel. The screen then went out and I am unable to turn on the oven. The interior light and stovetop, however, are still functional. I am trying to determine which part I need to repair this problem a) Oven Control Board #316101008, b) Relay #316113700 or Circuit Board #318111400. Or maybe it is something else altogether ??
Simon / APP Team
#2 Posted : Wednesday, May 8, 2013 1:29:17 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
If you feel comfortable to run voltage test using the multimeter then :
-unplug the range
-get access to the control board/oven clock
-remove the wire from DLB contact and make sure it's not touching any metal surface
-plug in the range
-check for 120VAC between L1 and N
-if there is a proper voltage then the control board is bad
And that's where the problem starts. The clock/control board is no longer available.
Simon.
Elle Dee
#3 Posted : Thursday, May 9, 2013 5:41:49 AM(UTC)
Elle Dee
Thank you for your help Simon !
Simon / APP Team
#4 Posted : Friday, May 10, 2013 2:10:04 PM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
GE Trutemp wall oven won't turn on (Oven Repair (including Ranges and Cooktops))
by Jim West Pa 4/3/2021 10:08:00 AM(UTC)
Oven won't turn ON on Bake setting (Oven Repair (including Ranges and Cooktops))
by hellotoall 6/22/2017 5:02:33 AM(UTC)
Oven won't turn on (Oven Repair (including Ranges and Cooktops))
by Viking85 12/18/2016 12:08:14 PM(UTC)
oven won't turn on bake (Oven Repair (including Ranges and Cooktops))
by crazyjohnny 1/8/2016 3:40:17 PM(UTC)
Maytag MERH865 oven won't turn on (Oven Repair (including Ranges and Cooktops))
by nmech123 8/17/2014 8:46:50 AM(UTC)
Oven won't turn on until knob is turned to really high temperature (Oven Repair (including Ranges and Cooktops))
by absoluteze 12/16/2013 8:24:07 AM(UTC)
Magic Chef gas oven won't turn on (Oven Repair (including Ranges and Cooktops))
by giantfns 12/23/2012 3:09:30 PM(UTC)
Monogram Oven Won't Turn On/Respond (Oven Repair (including Ranges and Cooktops))
by dcmcewen 7/9/2012 5:06:31 PM(UTC)
Help! Lost power & now my Thermador PGR366ZS oven won't turn on (Oven Repair (including Ranges and Cooktops))
by chocomom 5/7/2012 7:57:59 AM(UTC)
G.E. Oven won't turn on (Oven Repair (including Ranges and Cooktops))
by wannafixit 10/7/2011 9:40:53 AM(UTC)
by Hometown1 5/25/2011 2:30:35 PM(UTC)
Oven won't turn on unless stove is on (Oven Repair (including Ranges and Cooktops))
by chrisp0455 11/23/2010 7:12:06 PM(UTC)
whirlpool oven code F3 63 oven won't turn on (Oven Repair (including Ranges and Cooktops))
by lkaymen 9/24/2010 4:57:03 AM(UTC)
GE Wall Oven won't turn on (Oven Repair (including Ranges and Cooktops))
Belarus apachesurfer 8/31/2010 4:35:54 AM(UTC)
by brantd 8/27/2010 10:18:16 AM(UTC)
