I just replaced the ignitor in the oven and it worked, but the oven got to about 500 degrees and would not shut off. Could I have shorted the gas valve?
Groups: APP Team
Hi, Leesa.
Most likely it's not a gas valve. To provide you with more assistance we need the complete model number of the unit.
Simon.
Originally Posted by: Simon / APP Team ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Hi, Leesa.
Simon. The model number is JGBT32GEL2WH
Simon. Thermostat? Wired wrong?
Originally Posted by: LeesaBennett ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Thermostat? Wired wrong? Sorry that model # is JGBP32GEL2WH
Groups: APP Team
You need to check if the ignitor wires insulation is not damaged and bare wires not touching the cabinet. Then check the ignitor connector plug. If you have a multimeter then check the oven sensor resistance. At room temperature you should have about 1100 ohms. If all of this checks OK, then most likely it's a defective control board. It looks like this part is no longer available.
Simon.
