Dschoonover863
#1 Posted : Monday, May 6, 2013 8:59:15 PM(UTC)
Dschoonover863
My refrigerator just quit working. The light comes on but the fans and compressor are not. No noise at all.
#2 Posted : Tuesday, May 7, 2013 2:16:12 AM(UTC)
Parts for Whirlpool ET22DKXSW00 Refrigerator - AppliancePartsPros.com
See the attachment for a tech sheet.
Note that it is for a ET22DKXSW00. I could not find one for your exact model number but it should be close to yours.
First move the temperature control back and forth. if the unit fires up then replace the temperature control.
If the above does nothing, turn the cam on the defrost timer (item 4 in the Compartment Separator section). There is usually a hole in the cover to let you do this so that you do not have to take anything apart.
If the unit starts up replace the defrost timer.
File Attachment(s):
ET22DKX.pdf (248kb) downloaded 10 time(s).
Dschoonover863
#3 Posted : Friday, May 10, 2013 8:52:39 PM(UTC)
Dschoonover863
Thanks. Finally got a chance to find and turn the cam. Started right up. Need to order a new timer now.
