mmsampson
#1 Posted : Tuesday, April 23, 2013 1:31:16 PM(UTC)
mmsampson
Just replaced the lower bake element in my Maytag electric range for the second time. The problem is that this time the range will not heat up. The element is drawing electricity but not getting above 110 degrees. The broiler works just fine as does the touchpad. There are no fired or damaged wires attaching to the element. Any suggestions???
I NEED HELP! :confused:
scott5495
#2 Posted : Tuesday, April 23, 2013 2:52:12 PM(UTC)
scott5495
need a volt/ohm meter to test. if you have one let me know
mmsampson
#3 Posted : Tuesday, April 23, 2013 2:58:18 PM(UTC)
mmsampson
Brought a multimeter home today and checked the main terminals connecting the power to the stove and got 240 volts.
I turned the oven on and running 240 volts from each terminal to each side of the bake element.
Was that the correct procedure?
old Wall oven heating element problems (Oven Repair (including Ranges and Cooktops))
by shelliejh 12/6/2018 12:16:51 PM(UTC)
Heating Element Problem (Oven Repair (including Ranges and Cooktops))
by tasman 1/20/2013 3:51:45 PM(UTC)
Mold/ heating element problem (Dishwasher Repair)
by njnut 11/7/2010 8:45:54 AM(UTC)
Whirlpool Heating Element Problem (Dishwasher Repair)
by dwtiger 9/8/2010 5:06:44 AM(UTC)
Thermador heating element problem (Oven Repair (including Ranges and Cooktops))
by RSchuetze 10/27/2009 6:59:03 PM(UTC)
Heating Element Problem (No Heat) (Dryer Repair)
by Unknown 7/22/2008 2:18:59 PM(UTC)
