Brian Turnock
#1 Posted : Tuesday, April 16, 2013 12:24:54 PM(UTC)
Brian Turnock
HELLO,
My microwave oven control panel gives me a "DOOR" message whenever I press "start" to get things cooking. Everything else on the oven combo works fine. I have checked the three microwave oven door switches (primary and secondary interlock switches, and monitor switch), wires disconnected, and they are all okay. I just finished replacing the control panel and the problem remains. Now I'm thinking it must be a wire connection. I can't see anything obvious. If it means anything, the problem disappeared by itself for a couple of days, but now appears permanent. Thanks for any words of advice on how to proceed.
:confused:Brian
#2 Posted : Wednesday, April 17, 2013 3:51:29 PM(UTC)
Hello Brian,
Check for continuity the 20 amps fuse behind the control panel. It will cause such error code if it's blown.
- The fuse Part number: W10017410
Brian Turnock
#3 Posted : Thursday, April 18, 2013 9:45:02 AM(UTC)
Brian Turnock
Hello Gene,
Thanks for your reply to my question. I checked the 20 amp fuse and it's okay. Looking at your reply to Richard who had a similar problem, I'll check the 15 amp fuse on the back right and let you know what I find.
Brian Turnock
#4 Posted : Thursday, April 18, 2013 10:19:56 AM(UTC)
Brian Turnock
Hello again Gene,
I've been reading some other related posts and I understand that I should next test the 15A fuse at the back right of the microwave oven. Then the cavity TOD and the magnatron TOD. I'll get back to you if I can't figure out how to identify and test TODs.
Brian
Brian Turnock
#5 Posted : Tuesday, April 23, 2013 9:22:14 AM(UTC)
Brian Turnock
Gene: Once again, thank you for your help. The problem was indeed the fuse (20 Amp) at the back of the unit. Sadly, just as I was feeling really good about things, heating up a celebratory coffee, the door spring broke. At least I know how to fix this; I replaced one three years ago.
Brian
#6 Posted : Tuesday, April 23, 2013 10:38:26 AM(UTC)
You are welcome Brian. I'm glad you were able to fix it.
Guest (5)
"DOOR" message on micro wont turn on (Microwave Repair)
by kangaroo 8/29/2012 1:50:06 PM(UTC)
Whirlpool model GMC305PDB07 light stays on and has "door" message on display (Oven Repair (including Ranges and Cooktops))
by Luda 7/16/2010 7:17:26 AM(UTC)
by Luda 7/16/2010 7:16:54 AM(UTC)
"Door" message on display, unit won't start (Microwave Repair)
by RichardJ 12/11/2009 12:40:37 PM(UTC)
