brendangall
#1 Posted : Monday, April 8, 2013 7:36:24 PM(UTC)
brendangall
Just replaced the timer to fix the dryer, but it won't stop running. The only way to stop the dryer is to open the door or manually turn the switch to off. What else needs to be replaced?
#2 Posted : Tuesday, April 9, 2013 4:11:18 AM(UTC)
Parts for Whirlpool CEDX463SQ0 Dryer - AppliancePartsPros.com
What was the original problem with the unit?
Could be that the push to start switch contacts are welded shut.
Disconnect it and check it with a meter.
File Attachment(s):
CEDX463.pdf (507kb) downloaded 9 time(s).
Maytag dryer won't stop on timed dry (Dryer Repair)
by eaglemtn 11/11/2021 5:35:16 PM(UTC)
LG dryer won't stop tumbling (Dryer Repair)
by Danimal111 3/2/2018 9:53:47 AM(UTC)
Samsung Dryer won't stop running (Dryer Repair)
by Newbomb_Turk 12/6/2016 7:41:11 AM(UTC)
LP dryer won't stop running (Dryer Repair)
by rreyn 2/11/2015 2:53:15 PM(UTC)
Whirlpool Dryer won't stop running (Dryer Repair)
by Dave1234567 10/19/2014 5:45:40 AM(UTC)
Dryer won't stop running with heat-potential fire hazard (Dryer Repair)
by snowbound9 2/19/2014 5:37:54 AM(UTC)
Dryer won't stop spinning (Dryer Repair)
by Ddau 12/8/2013 6:15:22 PM(UTC)
dryer won't stop after cylces (Dryer Repair)
by isabelg 3/13/2012 8:58:26 AM(UTC)
Roper dryer won't stop on auto sense dry. (Dryer Repair)
by outbackblackjack 2/11/2012 12:56:06 PM(UTC)
by outbackblackjack 2/11/2012 11:14:53 AM(UTC)
Dryer won't stop heating! (Dryer Repair)
by geotreker1 6/6/2011 3:32:10 PM(UTC)
Dryer won't stop buzzing or shut off (Dryer Repair)
by talbany1 5/19/2011 7:08:01 AM(UTC)
Dryer won't stop and no heat (Dryer Repair)
by krazykarl05 2/3/2011 8:42:17 AM(UTC)
Dryer won't stop (Dryer Repair)
by nrowe46 12/4/2010 10:41:00 AM(UTC)
by dwiz 7/28/2010 9:57:16 PM(UTC)
