2 Pages12>
Joe D Raleigh
#1 Posted : Wednesday, March 27, 2013 6:49:51 AM(UTC)
Joe D Raleigh
I'm trying to trouble shoot an F2 error and need to know how to access the electronics involved - any tips of instruction guides available?
Simon / APP Team
#2 Posted : Wednesday, March 27, 2013 1:08:12 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Turn the gas and power off.
Remove the grates and burner caps.
Take out two screws holding each burner head and remove the heads.
Lift the rear of the cooktop and remove it.
Peel the rubber tape from around the top access panel, try not to break it.
Take out four screws and remove thew access panel.
To check the control board use the multimeter.
Check for continuity across P4-1 and P5-1, P5-2, P5-5.(take the wires off while testing).
If you have continuity between any of the contacts - replace the control
Part number: AP3753720
Post the results.
Simon.
Joe D Raleigh
#3 Posted : Thursday, March 28, 2013 4:42:37 PM(UTC)
Joe D Raleigh
Simon,
Thanks. I removed the access cover but the control card is located on the right side and not easily visible. See the pic below. Any thoughts on how to get better access?
Joe D Raleigh attached the following image(s):
Joe D Raleigh
#4 Posted : Thursday, March 28, 2013 6:34:45 PM(UTC)
Joe D Raleigh
I got access to the card - maybe not the easiest way but I got there. Now how do I unlatch the connectors that appear to have a living hinge type of latch. I am concerned I may break the latches?
Thanks again
Simon / APP Team
#5 Posted : Thursday, March 28, 2013 10:19:09 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Not sure a 100% but it looks like just simple pull out plugs.
Small correction on the test points.
Check between P4-1 and P5-1, P5-3, P5-4.
Simon.
Joe D Raleigh
#6 Posted : Friday, March 29, 2013 5:58:25 AM(UTC)
Joe D Raleigh
Simon,
I found continuity between P4-1 and P5-1. Now I just hope I remember how to put it all back together.
Thanks again,
Joe
Simon / APP Team
#7 Posted : Friday, March 29, 2013 11:28:15 AM(UTC)
Simon / APP Team
Groups: APP Team
You are very welcome.
Simon.
Joe D Raleigh
#8 Posted : Wednesday, April 10, 2013 4:35:42 PM(UTC)
Joe D Raleigh
Simon,
Well I'm closer.... Got the new card and it didn't quite fix it. I found out I had blown the fuse as well. Now I have a new fuse but didn't record the orientation when I removed the old one. Is the orientation of the fuse critical? There is the white conic material on one side of the fuse - should it be pointed in a particular direction?
Thanks Again,
Joe
Simon / APP Team
#9 Posted : Thursday, April 11, 2013 2:00:17 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
A fuse is non directional part.You can install it any ways.
Are you sure it's a fuse?
What is it's part number? Can you send a picture, Please?
Simon.
Joe D Raleigh
#10 Posted : Thursday, April 11, 2013 5:25:08 PM(UTC)
Joe D Raleigh
Simon,
Thanks - It is PN AP3872581
Guest (5)
2 Pages12>
