Ronald Walls
#1 Posted : Tuesday, March 19, 2013 1:09:09 PM(UTC)
Ronald Walls
:) Replaced Tfuse,checked switches voltages Now what to do
Simon / APP Team
#2 Posted : Tuesday, March 19, 2013 4:54:12 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You need to check the door switch, the timer, wire harness and the motor.
Unplug the dryer.
Using the multimeter check continuity from C to NO at the door switch (door closed, one wire off the switch). If you read continuity - go to the next step. No continuity - replace the door switch.
Set the timer to TIME DRY. Contacts L-H, TM-N, L-M should have continuity.
Also the M-S when the timer knob is pushed in.
If the continuity tests out OK, check the wire harness to the motor and door switch.
Replace the motor.
Please post the serial number of the dryer.
Simon.
Kenmore Elite dryer won't run... (Dryer Repair)
by J C Jones 9/11/2021 9:09:42 AM(UTC)
Kenmore Dryer won't run (Dryer Repair)
by gman536 3/14/2021 3:37:08 PM(UTC)
Dryer won't run unless start button is held down - no heat (Dryer Repair)
by jstrefeler 9/24/2017 12:10:11 PM(UTC)
Dryer WOn't Run (Dryer Repair)
by wstvpawjr13 5/14/2017 12:23:41 PM(UTC)
Dryer won't run after releasing the on button (Dryer Repair)
by Heathers1988 11/9/2016 4:20:53 PM(UTC)
Amana Dryer won't run (Dryer Repair)
by Paige Tremblay 1/26/2014 6:06:08 AM(UTC)
dryer won't run (Dryer Repair)
by dymetz62 1/8/2014 5:00:20 PM(UTC)
by pmclaughlin@apins.com 4/9/2013 11:18:38 AM(UTC)
by Ronald Walls 3/19/2013 1:06:28 PM(UTC)
by loumemoli 7/2/2012 1:33:54 PM(UTC)
dryer won't run but heats up fast (Dryer Repair)
by w. carroll 3/28/2012 8:22:26 AM(UTC)
Dryer Won't Run (Dryer Repair)
by paul888 1/16/2012 1:37:57 PM(UTC)
Dryer won't run after start. (Dryer Repair)
by clparks 4/28/2011 9:49:25 AM(UTC)
by tterry 3/29/2011 10:49:47 AM(UTC)
by DarrelD 1/31/2011 1:09:02 PM(UTC)
